Modifying viewports
There are various ways to modify viewports; their appearance can be completely different from the original design layers for presentation purposes. For a styled viewport, you might need to edit the style or change the viewport to be unstyled before making modifications; see Creating and editing viewport styles.
Modification
Description
Access various viewport editing modes; set preferences for editing viewports
The Edit Viewport dialog box
Change the settings for the viewport in the Object Info palette
Viewport properties
Edit the viewport style
Modify the viewport with various 2D and 3D tools and commands; copy and move viewports
Moving and editing viewports
Add annotations and dimensions to the viewport
Creating annotations for sheet layer viewports
Add depth cueing to sheet layer viewports and section viewports
Applying depth cueing to a viewport
Crop the viewport
Cropping existing sheet layer or design layer viewports
Edit one or more design layers in a live section or elevation
Editing design layers from a section or elevation view
Edit a design layer displayed in the viewport
Editing a design layer displayed in a viewport
Change the visibility of objects, classes, and/or layers from the design layer or when editing a linked camera on a sheet layer
Changing viewport visibility
Edit or delete a linked Renderworks or video camera
Editing a linked Renderworks camera or video camera
Change the properties of the viewport's layers and classes
Changing the layer properties of sheet layer or design layer viewports
Changing the class properties of sheet layer or design layer viewports
Change the attributes of the objects in the viewport based on their data
(Design Suite product required)
Applying a data visualization to a viewport
Change the visibility and appearance of structural grid lines in viewports
Structural grid visibility in viewports and Grid line instance visibility in viewports
Modifying section viewports and section lines
Overriding viewport display
Viewport status
Updating viewports
Viewport styles
